I have a 1990 Evinrude 48 SPL and I just rebuilt the carbs and the fuel pump. To give a little back ground, the boat sat for about 5 years. I did those two things right from the get go. When I start it up it fires right up and runs for about 8-10 seconds and dies. Sometimes I can keep it running longer by pressing the key choke in when it starts to die. I did find the primer choke thingy and the red lever was facing about the 3 o'clock position at its detent. I moved it to the 11-12 o'clock position and it will idle on its own and sounds ok. Obviously Its probably not where it is suppose to be and Im guessing Im not getting enough fuel. Where should I start? Thanks in advance for any help.
