carb leak!
willthrill
I have a 1988 85hp motor.Gas leaks from the first carb on top when pumping bulb with the engine down in the running position.New fuel pump and primer bulb.HELP!!!
sailingwest
Re: carb leak!
Hi, Sounds like you may have a sticking float needle ,you may have pumped some crud into carbs at pump service,strip and clean carbs and check float height adjustment . Jim B
