Carb issue
Sbcwrangler
1976 55hp Johnson hasn't been running right since i bought it. decided to change the plugs and clean the carbs. Had the carbs apart last night and cleaned them with seafoam and chased all the passages with a wire.put them back on today and ran it. Engine still seemed like it was missing. Sprayed seafoam in bottom carb and the idle dropped and produced a little smoke. Seemed normal to me. Sprayed it in the top carb and the idle speed up substantially and the engine smoothed out. Disconnected the linkage to i could operate 1 carb at a time. Bottom carb responds immediately but top carb gargles and lags and never causes an increase in revs. Any ideas on what could cause this?
Honorary Supreme Mariner
Clearly this points at an issue with the upper carburetor.-----Did you remove the high speed jet for cleaning ?---It is screwed into the bottom of the carburetor bowls and is about 5/8" long.----
Sbcwrangler
No I didnt remove it. It didn't want to come out without a fight so I left it alone. Looks like i should probably revisit that
boobie
If you have to fight the jet, run a packing wire through it and then compressed air.
Sbcwrangler
That's what i tried last night when it wouldn't come out. Thought i had done a good enough job but maybe not
60sboater
It's not hard to miss something when servicing a carb. I blast carb spray through every passage and orifice and follow with canned air. Sometimes,as stated,you need to mechanically clean an orifice etc with a wire or similar. How's the needle and seat and float condition and level? Good luck.
Sbcwrangler
Needle, seat and float look good as new. Previous owner said it wasn't used for 10 years. Looks to me like someone put a kit in it tho. I read somewhere that the float should be set level. Does that sound right? That's where it is set now
Sbcwrangler
No joy. Took top carb off and apart again. Bowl was full of fuel and i verified that float and seat were operating. Seafoamed it and chased passages with cable. Nothing seems wrong in the carb at all. Reinstalled it and fired it up and it still acts the same. Top sarb does mot seem to be providing any fuel at any time. Operating its throttle plate makes the engine sound labored. Closed the choke plate while it was running and had no effect. Sprayed seafoam while running and idle took right off and wngine smoothed out. Everything points to the top carb not functioning properly but what else can i try?
Coreect me if I'm wrong but for the high speed idle to work all that is required is a bowl full of fuel, clean jet and vacuum from the engine that will vary with throttle plate movement. Am i missing something? This has me baffled.
boobie
Maybe I missed it, but have you checked the compression on it ??
Sbcwrangler
No I haven't yet because I don't have a tester but it did cross my mind. Must have half decent compression if it runs great temporarily off a spray of seafoam tho right?In the meantime i adjusted the float to raise the fuel level a touch but it had no effect.
oldboat1
Don't get agitated now, but are you confusing the high speed orifice down at the bottom of the carb (See #2-5 posts), with the float valve seat? The valve under that screw at the very bottom is the one that gets plugged up. If you sprayed seafoam through the throat of the carb you might not have cleared that h.s. orifice.
Sbcwrangler
Not agitated at all oldboat. Any and all thoughts are appreciated. Ran a heavier wire through that orifice this morning and actually dislodged another piece of debris. I reinstalled the carb and ran it. Runs a bit smoother now and engine now responds to theottle plate movent in the top carb but there is a new issue. Top carb is now spraying fuel out. I reset the float to level already but its still doing it
bonz_d
Try again. Once had a 1966 18hp Evinrude that I had the carb apart 4 times before it would run right and that engine has only 1 carb.
1st of all ditch the Seafoam and get a large can of GumOut carb cleaner. Next get 1 rebuild kit. Use the GumOut with the straw and spray into all holes. On the throttle body there is a brass tube with a smaller tube inside it. Spray those really well and run a wire thru them. Those are the high speed and low speed pickup tubes.
On that top carb use a new kit on it, I have found these engines are prone to sticking float needle valves and replace all gaskets. Make sure you have a good seal at the carb mount. Recently had a 50hp that was doing this same thing. I tightened down the mount bolt each 1/2 more turn and the spitting stopped. Also trim back the fuel lines about 1/4" before putting them back on.
oldboat1
change is good -- signs of progress. On the right track. Check earlier post (Dabbler_E) : "Fed -- WHOO HOOO! Took me a while to find the bowl vent but it was indeed plugged up. Cleared it out, problem solved!"
I would be inclined to soak (resoak?) the carb, and run a wire through all openings (gas, fuel, AIR, screw holes, dents.....), then blow carb cleaner in the holes, maybe air as well. And hit the hs orifice again with carb cleaner. Five (6?) times is the charm sometimes.
(+2 to bonz-d's post)
Sbcwrangler
Thanks for the ideas and feedback. Much appreciated. Got it soaking again now. What is this about a brass tube with a smaller tube within it? My brass tube that threads into the throttle body is hollow with 4 small holes in it. No inner tube. Bottom carb is the same
bonz_d
You are correct, my mistake. been working on too many of these lately and they are all running together.. The 35hp I'm doing right now has the 2 tubes. Just sold a 1975 50hp, pulled a 1983 60hp from my boat and replacing it with a 1987 50hp that has just been converted from VRO to a pump.
Another thing you might consider would be to change all the fuel lines inside the engine. If they are old and deteriorating they can mess up a new carb job in a matter of minutes.
oldboat1
soak the brass nozzle with the carb body, and spray it out with carb cleaner, then run a wire through the holes and spray it again (away from your face). Stuff has to be squeaky clean, and the nozzle could be part of the clogging issue. On track, I think.
(should be a cork washer/gasket that fits on top of the nozzle when reinstalled, if typical.)
vrodrig
Hey gents, you may want to try using a sonic cleaner. Get one for about $60- $70 at Harbor Fright and use Simple Green and water (no harsh solutions) to vibrate all the junk thats in those carbs out. Iv been doing this for years and it works great. I have used this on weed eater carbs to boat carbs and everything in between. Its also has other uses for like jewelry and small things of that nature. Yeah when you see how well the clean you'll be looking for things around the house to sonic clean.
Sbcwrangler
Soaked it overnight and reassembled it. Installed it with new fuel lines as suggested. It is still blowing fuel out the top carb but there is a considerable difference in idle. Mid to hi idle is strong and smooth. Gets a little slow and rough at low speed and dies when put in gear. Low speed jets have been set as per sticky instructions. Pleased with the progress but top carb obviously needs more attention. I was reading something about reeds in the intake being stuck or broken. Trying to school myself on this. This my first outboard experience
oldboat1
Both carbs would have core plugs up at the top by the low speed needles. As part of carb cleaning for idle issues, the plugs need to be removed, and the small openings underneath checked and cleaned. The low speed needles need to be checked to be sure the points are not bent or broken. I don't think the fuel spitting (top carb) would be related. But given the changes in operation (and symptoms), I would guess from here that both symptoms are still carb issues with one or both carbs.
