carb help
twisted039
hi guys i put a new float and needle in my lower carb, 3 cyl 65 hrs 1972 evenrude.i was lacking power i now have lots of power but after awile she surges like she is starving for fuel, primer balb is still hard, rest of carb parts were good, any ideas<br /> thanks
Re: carb help
no genuious but alot of times the carb has to be cleaned out. I had a simalar promblem with one of my outboards and cleaned the carb out with carb cleaner only to find the same thing happening. Cleaned it out again and found a small hair like thing clinging to the side of the needle valve. After that outboard ran great. HOPE THIS HELPS YOU .
ob
Re: carb help
mikezess, make sure fuel tank is venting and pick-up tube is clear.Also insure fuel line connectors are sealing properly .
12Footer
Re: carb help
You may have a fuel pump going bad on your engine.<br />The diaphram gets eaten by alcohol in alcohol "enhanced" fuels. They also dry rot after a couple years. Good news is, the rebuild kits are cheap, and they're fun to rebuild.
twisted039
Re: carb help
u guys are great ,,,,, ill rebuild the fule pump ist easy,also i hear a wistle sound from back there could i have a bad conection air leak?
Re: carb help
One way to find a air leak is to spray some wd40 in the area which you think the air is leaking with the motor runing if it boosts your power you defenitly have an air leak
