Guys, I have a 1977 Evinrude 75hp. I recently rebuilt the engine and have broken it in. Prior to that I also rebuilt the carbs. According to the manual I do not have 1977 carbs on the engine. It appears to be 79-82 carbs because they have 3 orifice holes instead of two, one top center, one top right, and the other lower center. I know the adjustments are wrong because it is slow to plane, dies if I try to apply the throttle quickly and I cannot lower the idle below 1200 rpm. It also sounds as if it is sneezing at idle speed while in the water. Are these orifices adjustible? I looked on the carbs and each one has a number stamped on it. I cannot find any of these numbers in any sites I've checked. Can someone point me in the right direction?<br /><br />Thanks
