carb float level
micar
I have an 81 model 70hp Evinrude out board. Can anyone tell me what the float level setting is for this motor??<br /><br />cheers <br />mike
JB
Re: carb float level
G'Day, Micar.<br /><br />Your manual usually gives instructions. If you don't have one, get one.<br /><br />In the meantime, Most engines will perform well if the float is set so that when you turn the carb top over the top of the float is parallel with the gasket surface.<br /><br />Good luck. :)
12Footer
And it will be the best 20buks you ever spend on your motor, as it will pay for itself over and over again.
