carb float holder
renny1
well i was cleaning the stromberg carbs on my AQ130A volvo and i broke the arm that holds the floats to the carb(the ones that are attached to the inside of the carb body my question is
is there a way of getting them stuck back on with metal weld or solder or would it be easier to source another carb?????
Don S
Re: carb float holder
I don't have a clue!
JustJason
if you broke something integral to the carb... then get a new carb.
ccmarsh
Carbs are expensive what are you nuts?;)
Find the manual for the carb you own find the name of the part and the part# and see if you can't get a replacement part. Try that before you go and buy a new carb.
Robj
Capt is right. If I understand this posting correctly, he broke part of the carb casting that holds the pin for the float. In which case Capt is correct. You may want to make sure you know what you are talking about before you start calling someone nuts!!!
While I may not agree with everything Capt says, he does have alot of experience and expertise with boats, probably more than yourself.
Have a great day,
Rob.
JustJason
Awww thanks RobJ... your gonna make me blush...
I'm not as good as Don S, or Bondo or Rodbolt..... (and i'm not as old either!! jab jab!) But i've been around a little bit. I'm a good middle man!
Carbs are expensive.....
Boating is ridiculous......
But being broken down 5 miles off shore is priceless :)
I'd bet a dollar that he could JB Weld the part back on and it would stick....
But I'd bet 2 dollars that the float would stick all the time.....
CCMarsh... Not every carb can be rebuilt. Throttle valve shaft seals wear out and are not serviceable.
If somebody brought me an original carb off of a 71 anything... i wouldn't even open it up... i'd punt it.
If you have an idle that just won't come down, if you have an engine that spits and pops.... and if you have a motor that is mysteriously burning valves.... the last thing you want to do is "rebuild" a 37 year old carb.
ccmarsh
That was a joke, hence the little icon I put next to it.
Have a great day,
Rob.
If you have ever read any of my threads then you would already know that Capt has more expertise than me and I never tried to make an impression that he didn't. Capt has helped me out trememdously already and I am greatly appreciative. If anything I say bothers Capt I'm sure he'll let me know.
Sorry Capt.
JustJason
No worries mate... we're all here to live and learn.... and to laugh at the expense of those who don't listen... :) :)
Robj
No problem guys.
I have broken the part renny1 is talking about, but on an outboard. Those ears are part of the casting that hold the pin that the float hinges on. I ended up buying a new carb, because it could not be repaired. You should be able to find a used carb for much less than a new one. That IMO is your best choice.
Have a great day,
Rob.
renny1
No problem guys.
Have a great day,
Rob.
thanks guys and yes it is an integral part and i jb welded it but have not tried it and im not going to as i have just sourced 2 carbs for ?25($50) each so i will snap his arm off for them
is there anything(apart from new gaskets and setting tick over) i need to do once the other carbs are on???
Robj
I would probably put a rebuild kit in them. That way you know they are ready to go. BTW watch the ears for the float pins. lol. Been there, done that.
Have a great day,
Rob.
JustJason
pull the jets out of the old carbs and the new carbs and look at the numbers to make sure they are the same size... if they are not, or if you can't tell, put your old jets (clean obviously) into the new carb.
