I have a 1988 Johnson 150 VRO (TX Model) with of coarse plastic carb bowls. Which naturally warped (again). They were replaces 3 seasons ago this being the 4th season. I pulled the carbs off and did a good cleaning prior to my first trip out this year. And even though the engine ran great when I came back in and parked I pulled the engine hood just to take a peak and surprise surprise the middle carb and possibly the lower are both leaking fuel. Pulled back off and put the bowls on the plane and they are warped for sure.
Ok the question.
I have a 1982-84 (it has conflicting numbers on the engine) 150 VRO here as well. And it has aluminum bowls on its carbs.
I have been reading any post that came up in the search. Im aware most likely this wont be a direct replacement, unless I can swap the entire carbs over to mine?
Is this a possibility? They look identical to mine. I cant find any thing that has jet sizes for each with certainty. Any literature I have found give several options of jets that could be in there.
Any insight would be great, thank you in advance!
-Frank
--Pennsville, NJ
Ok the question.
-Frank
--Pennsville, NJ
