Carb and timing
5string
I haven't had time to do anymore with my new to me 93 70hp Force but I read alot here and everywhere else I could. I'm waiting for a calm day that I can get on the water to set high speed timing. I started it up Sunday and noticed if I start it cold and keep pushing in the key to choke it every couple seconds it doesn't sneeze at all and idles well. So I do think the carb is the problem, I would think if the fuel pump was bad it wouldn't run wide open like it does. So I need to take the carb off and clean it, I'm a little skeptical about soaking it in anything but what do you all say is the best way to get it clean? I'm also looking for a kit and confuse as to what part number I actually need, it is a single carb Tillotson TC-111B401 826369.
5string
