Hey Guys,
My carb on my 77 Johnson 35hp was leaking fuel pretty badly. I adjusted the float drop so that only dropped about 1/2". Before, the drop was much lower. Took it out to the lake and the leaking stopped until the end of the day, when it leaked again.
It seems like I still haven't got the drop set shallow enough yet if it still leaked a bit. My question is, if I set the float drop too shallow, will I starve the engine and cause it to run too lean or overheat?
Thanks-Jeff.
Thanks-Jeff.
