chris in houston
Thread starter- Joined
- Jan 19, 2010
- 23
Bought a 2000 Bass Tracker with same yr 60 HP Tracker Merc (3 cyl, 2 cycle). Motor runs great off idle, but idles a little rough at 700 rpm (on dash tach) in gear. I played with idle screws on carbs, but between too lean and too rich could not find a happy smooth setting.
As I leaned out each carb, RPM did not climb - just started stuttering once I got too lean. Also, blue smoke seems a little thick at idle, like it's maybe too rich.
Also, even when warm I need to push throttle forward in N to get to start without it dying. Then when I back throttle down to idle it will stay running, though a little rough. As throttled up to speed, there is a perceivable RPM at which it goes from what seems like a miss to a smooth, all cylinders firing acceleration.
Plugs have been replaced in last 12 months. Wires look OK. Not sure carbs have ever been worked on.
Fine Merc people, please weigh in on how I can get this thing smoothed out. Thanks!
