Car CD player Ok in a boat?
Mark42
I have the opportunity to install a CD player/radio from a Chrysler in the boat. Just wondering if the CD player will mis-track on the water or are marine cd players designed to take the pounding without skipping.
The player would be mounted in an area protected from the salt and elements.
dingbat
Re: Car CD player Ok in a boat?
Marine units tend to have higher sampling rates. Skipping has never been an issue and I beat mine to death. I can't say for sure about the car player unless you know the sampling rate of the unit in question to compare it to mine.
Unless you have the unit is completely sealed from the environment your bigger problem is going to be the electronics. The electronics inside a marine unit are coated with plastic to protect it from the salt air. Without this protection the salt air will premature the unit and eat it from the inside out in no time.
We wasted the PCB on my wife's video camera on single afternoon trip. The camera stopped working about 3 weeks after the fact. Opened it up and just about every termination on the board was green w/corrosion. Cost $175 bucks to replace the PCB.
okboating
I know I might not post much, but I'll give you my 2 cents. I have run standard cd decks in my boats (currently on my 3rd) and have never had any issues. One of them was a 16 stratos runabout very similar in size and hull design to your boat. I have also used my regular automotive decks 4 wheeling and muddin my old jeep. I would suggest getting a unit that will play mp3 disk and maybe even an input for an mp3 player. We make these lake disc, and a standard cd can hold almost a whole days worth of music in mp3 form.
Just make sure that it has a marine cover (but it might not be necessary under your new top).
Dave
flargin
if you are near the sea, then the salt water is a ***** on the electronics. You are in NJ, so the humidity may not be great... I live in colorado, and use marine speakers, and a car deck.. never had problems...
there is nothing critical about them, so if it dies you may have a boring trip home, but you will be home. I guess if it dies in a year.. you should have gotten a marine unit... :)
You have more humidity then I do... but it will likely be fine.
BTW, forget the CD player go with a usb interface and a thum drive. 32 GB of music will keep you running for a month and no moving parts to break....
