Capsized Boat in sea water !!
Roderick
Lately our 17 foot boat capsized due to heavy rain and stormy weather while it was anchored at shore. The engine thus went under water for a few hours. The engine is a 35hp 3cyl built in 1998 with power trim, tilt and starter motor. We don't know exactly what parts to change because of further corrosion... Parts like the stator and the powerpack need to be changed i assume... What is the proper procedure to flush the engine completely, service it and avoid future trouble? The engine was started, sprayed and filled with WD 40 (penetrating oil) for now... <br /><br />Opinions are much appreciated !
crazy charlie
Re: Capsized Boat in sea water !!
Run it!Rinse it!Spray it with wd40!!Rinse it!!!Fog it,Spray it .When you let it sit the trouble begins.Charlie
Jack Shellac
Well, when mine was under salt water for about 24 hours, took it to the dealer and they hosed it off, let it dry for a while under a fan and fired it up. I was amazed when it started and kept running. Never had any trouble with it later, either. Hope you're this lucky, too. Most likely problems would be with electrical systems, I would think. Like Charlie says, the most important thing is to run it if it will run.
