Can't ID old Montgomery Ward... Please Help
camccardell
found an old montgomery ward in the back of the garge, and it looks rather rough.<br />Found some #'s though and could really use some help in identifying it or getting some literature on it.<br /><br />Here's what I have<br /><br />Model # 84GG9007A<br />SN # 191460<br /><br />Any help would be greatly appreciated
dwayne druyor
Re: Can't ID old Montgomery Ward... Please Help
i think i have the same thing...<br />montgomery ward 1.5 hp<br />model#84gg9003a<br />sn#251205<br /> this is all i have <br /> thank you
tmcalavy
Reverse the first two numbers of the model number and you get 1948. The 9007A should be a 3 hp. Both are 1 cylinders I believe, made by Gale...the generic mfg. division of OMC/Evinrude/Johnson up until the early 60's. Very good motors, simple, reliable, easy to work on. Keep em and run em.
camccardell
ok, cool<br />any idea where I can get parts for it?<br /><br />the spark plug wire has been cut
alderman
Parts for the old gale motors are available at all NAPA stores. Just make sure to take the model number with you. I have a 1963 5 hp SeaKing (Gale) so far I have been able to get water pump kits, carb kits, plugs, points and all electral parts from them. Mine is a strong running old motor and I perfer it to a 25 HP evinrude I have. Just depends on were I use them.<br />Good luck and let us know how she runs.<br />Ray
steelespike
Unfortunately I think you will find the parts for your older motor are not as easy to find or match with E/J motors.Parts from other Gale built motors of similar design might work.Also<br />some Johnson ignition parts of approximately the same year may fit.
tmcalavy
Check the links page at www.aomci.org, there's always someone who has NOS parts in stock or can get what you need...just takes a little phone work.
