Can't get it running
Simba674
Need some ideas...carb cleaned, new plugs, points cleaned, checked compression (equal on both), correct fuel mix but just won't run. Did have it started at one point, ran for about a minute after 20 minutes of trying. According to model number it's a 1963 johnson 10hp (model od-24m).
merkdawg0084
Check to make sure you're getting enough spark. Make sure vent screw is open on gas tank, adjust your slow speed jet and make sure your fuel pump is working. Not sure if your model has fuel pump or pressurized gas tank?
boobie
Will the spark jump a 1/4 " open air gap on a spark tester ??
oldboat1
If you test for spark as boobie suggests -- and have 1/4 inch and a strong snap -- spray some premix into the carb and see if it will fire. If so, chances are you missed something in the carb work or don't have the mix set correctly.
F_R
Honorary Supreme Mariner
You didn't say anything about the coils. If they are the originals, they most likely are shot. Yes, they can still have spark, but run like crap or not at all.
