Cant Find The Year Anywhere
biggern
Please help me find the year of my mariner OB224644 45hp 4cyl 2 stroke looked everywhere cant seem to find it PLEASE HELP!!!!!!!!THANKS
AMD Rules
Re: Cant Find The Year Anywhere
That's a 1987 motor, and a real nice 4cyl motor. Known as a Mercury/Mariner "Classic 45"
biggern
how can my boat say oil injected but it has no resivor for oil do I need to use mixed gas and if I do what is the mixture.... THANKS need big time help the boat was given to me AMS does rule Thanks for your help!!!
AMD Rules
Your motor would have came from the factory with a 'boat-mounted' oil reservoir for injection purposes. Mercury called it "AutoBlend". They aren't very reliable and most people (including me) removed them anyways.
You'll need to premix your fuel 50:1 with a good quality TCW3 rated oil for 2-stroke outboard motors.
biggern
Thanks AMD you have helped me big time hope you have a great year of boating Im sure I will need your help again THANK AGAIN!!!!!!!!!
AMD Rules
Pay it forward. Best of luck with your new boat/motor.
biggern
AMD can answer anything and quick.....big time appericiated.!!!!!Where should I get new spark plug wires for it.(45 clasic) Im located in ONT Canada.Just need your opinion,you seem to obviously know alot about your motors!!!!!!THANKS you helped me big time!!!!!!! Im LOST!!!!!!
AMD Rules
I purchase my parts through my local Marina (Merc dealer), but if you're handy you can likely pick up some bulk solid core wire at your local automotive place cheaper and re-build your own wires.
All your local Merc dealer needs is your serial number, and they can get you any part you need. Most parts are still readily available for that motor.
To be fair to iboats, you can probably buy them here online as well. I'll have a peek and see if I see it.
AMD Rules
iboats does sell them (Sierra aftermarket), but they don't have stock anyways.
Merc p/n 813715A5 CABLE SET-IGN should list out at approx $50USD for the set of four wires.
Spark Plugs are NGK BUHW-2 , available almost anywhere.
