Re: can't find idle mixture screw
It is unlikely that the idle mixture screws have turned themselves out making the mixture too rich.
Instead, it is far more likely that one or more carbs are flooding, or the fuel pump diaphragm has worn a hole in it allowing raw fuel to dump into a crankcase.
With the motor OFF, adjust the trim level, remove the airbox cover, open the throttle WOT. LOOK down each carb throat while you pump and hold the primer bulb to see if ANY fuel is leaking anywhere. If so, you found your problem.
If not then remove the fuel pump from the motor but leave the fuel hoses connected, again pump and hold the primer bulb while watching the vacuum port of the pump for fuel leaking indicating it is time for a fuel pump rebuild kit.
If both the above check out, check for adequate spark on each spark plug wire, a dead cyl will leave unburned fuel and cause fuel smells.
