Re: Cannot figure out a lean running 93 140hp
Another update:
Spent some more time on it today. I bought a 3 gallon portable tank and filled it with 50:1 premix. I wanted to be positive it was getting enough oil and I can rule out the tank in the boat, water filter, old gas, etc. Still ran pretty much the same. Still didn't smoke much. This is the first 2 stroke outboard I've seen that doesn't smoke when it's cold.
I also bought an infrared thermometer. After running the motor for a while I shut down and checked the temps on each of the thermostat covers. Port side was 115-120, starboard side was 160. This seems odd to me, not sure what it means. My service manual says it should be between 120-150, but it seems odd that each side would be so different.
While it was running I tried spraying fuel down the carb throats. The starboard side of the engine clearly isn't running right. Spraying down the carbs on that side would cause it to perk up a bit and run better, while spraying in the port carbs would immediately make the engine stumble. I tried spraying at the plates on the sides of the carbs and at the throttle body connections, but this didn't seem to do anything.
I'm really lost at this point. It seems like the starboard side isn't getting enough fuel, but when I pulled the plugs right after running it they were covered in carbon and seemed somewhat wet(they're fairly new). I guess the head gasket could only affect that side of the motor, but compression is fine, so it's not obviously bad. Both thermostats are brand new, as is the water pump.
Long story short: Motor won't idle, starboard side hotter than port, extra fuel seems to help, plugs look slightly fouled.
