Can you rebuild a 79 15hp Johnson fuel pump?
mrtapes
I have another thread regarding this engine and am ready to buy some parts to rebuild the carb etc..
Before I buy, I have a question as I am seeing conflicting info regarding the fuel pumps of this era.
I have a repair manual that says the pumps are non-serviceable but in this thread http://forums.iboats.com/showthread.php?t=365324&page=1 BKTHEKING gives reference to a pump kit stating to replace the diaphragm.
Can these pumps be rebuilt?
Can someone help clear this up for me?
the machinist
Re: Can you rebuild a 79 15hp Johnson fuel pump?
If you go back to the opening page of this forum & down to "Engine Repair & Maintenance" then to "Frequently Asked Questions", down near the bottom you will find a link to "9.9/15hp repairs".
This link will take you to my many articles on repair of these motors, with one showing how to rebuild one of these fuel pumps (using factory instruction sheets).
The reason some say this fuel pump is not repariable is that you will not see a repair kit for the early ones. The situation is that the newer pump bodies have an ear on the sides of all of the bodies, which gives you some reference as to how they go back together on reassembly. Apparently the experts did not think that a person could use a felt marker to mark all the body parts with one swipe before dissassembly. The new kits will fit the older pumps.
However do your repairs on a CLEAN table & not on a carpet floor as these pump units have small delicate springs behind the check valves that need to be in the proper place & not allowed to flop over. If it does not work take it apart & try again.
mrtapes
Thank You!
I've actually been on this website that post links to already. There is some good info there.
Thanks again
mrtapes
I did this rebuild today!
Absolutely no issues at all. The engine runs great!
If you follow the directions that come with the kit it's a snap.
The directions BTW were exactly as posted HERE.
