Can you ID this Minn Kota?
Wrfkaratemonkey
If anyone can tell me the model / thrust I would appreciate it!!
ThomW
I can tell you it's year is 1993. That is the only year the serial numbers started with MK and ended with an A. The thrust is not as easy to find. I would guess maybe 36-40 lb thrust. You can always try calling Minn Kota and giving them the serial number to see if they can tell you.
Wrfkaratemonkey
I called them based on your advice. They confirmed 1993 but said the serial won’t tell them the rest. They told me to take the motor cover off and there is a label on the inside of it with all of the information.
It shouldnwork fine for my 11ft jon boat. It’s not very heavy
Wrfkaratemonkey
They were wrong, no label. I’ve decided I don’t really care. I just need to fix it. When it’s hooked up to battery is is always on and at one speed. Turning the selector does nothing. I’m assuming the switch has gone bad.
Wrfkaratemonkey
They got it from the motor! It’s weaker than I would have liked, but based off the general ratio for thrust vs weight I think it’ll work fine. At least for now!
