Re: Can you add Octain Booster to fuel on a outboard motor
Too high octane in an engine that doesn't need it will cause a loss of power, because the fuel will not ignite properly, nor burn completely. I have a 1970 AMC with the original, stock, unmodified motor. I add 1 gallon of leaded race gas to every half tank -not for the octane, but for the lead for valve lubrication. One time, on a lark, I filled up on race gas (when it was still "cheap") and the car wouldn't get out of it's own way.<br /><br />The lead was put in the gas to prevent erosion of the valve seats, and the octane boost it gave was a secondary benefit. Since the early 70's, automotive cylinder heads have had hardened seats installed so that low-, then no-lead fules could be used.<br /><br /><br />BTW - if you can get race gas, it is a much better way to boost octane than those little cans - A gallon will raise it about the same amount, a gallon costs about the same, but a gallon will move your gas needle further than that little can!<br /><br /><br />Just another bit of info for the discussion...
