orlandoclippertim
Thread starter- Joined
- Jun 2, 2011
- 106
I have an original Orlando clipper trailer. Was looking at the axles and hubs. It has small 4 stud hubs. The axles are
1.5 inch SOLID square steel with the spindles turned on the ends so it is all 1 piece. The spindles -- where the hub
bearings slide on is completely straight and 1 inch in diameter. Inside the hub- the inner bearing is non-tapered---
and the outer bearing is a tapered bearing between the hub and bearing (but its center is straight to slide onto straight spindle)
I think I see that the inside of the hub has a removable race . I guess the inner one would have just a cylindrical pocket.
does anyone know if this system is OK in use ? -- and can I find parts for it like races and bearings ?
would I just be ahead all around to build a new axle /hubs from northern parts so I have a modern system that I can
get parts for easily? I guess this is a practical use question----
Also -- if I do build a new axle--- would it be better to go with a 5 lug hub so I can use a bigger wheel than the teeny
12 inch ones that it had ? (thinking lower RPM at road speed for any extended trips) and less tire heat. fewer of the
"on the side of the road" incidents with bigger wheels-tires. Might get a better quality of tire that way maybe ?
Opinions ?
Tim
Opinions ?
Tim
