I may be replacing my Mercruiser 120 (cracked head) with a 140. The 120 is setup for an 'R' out drive and the 140 is an 'MR'. I have the inner transom plate and gimbal assembly to convert to the MR. However, I don't have the trim pump that came with that setup. The 'R' trim pump is mounted to the inner transom plate currently and I don't see a similar mounting location on the MR.
Can I use the R trim pump with an MR outdrive if I make a new mount for it?
Thanks
Thanks
