Re: Can I trust the original factory transducer placement?
Well................ in this case I guess the factory did have the proper transducer location nailed, however.... I found that they chose to glue at the angle the hull presented rather than try to find a more level area OR to level that area.<br /><br />My decision was to use that location, but to provide a more level mounting surface. SO... After levelling the rig in the drive, I ground the high side down about as far as I dared (I was pretty conservative), cleaned up the spot and mixed about a half a cup of JB weld and poured it in. Area pretty much self levelled and only needed minor work to provide a clean, solid level mounting surface for the transducer. <br /><br />I also took some more advice gleaned from this board and used the 3M 4200 sealant to glue the transducer, just in the event that I might have to move it. So far, I am mighty pleased with everything. Thanks for the advice, all!<br /><br />/mike
