1979 Rude 115. The manual tilt release valve is working fine and the engine falls down to the trim rams (which are stuck up). My question is: If I need to fish this weekend... how do I get the trim rams to come down manually? Is there a way ?
Looking at the back of the motor go to the right side to the piece that bolt to transom you will see a flat blade screw that is a bypass loosen it and the motor will go down with a little help but tighten it back so that everything will work properly if you hit something or use reverse
Thank you 1983 ercoa 21' ! Yes. That MRV work fine for the engine tilt. The motor will come down till it hits the trim rams. How do I get the trim rams to release?
Thank you Racerone - Does the manual release have to be open for the engine to push them down in the water ? I've put some pretty good pressure on them in the garage and they aren't budging. Obviously, the tilt-trim is not working. It pushes up strong but will not pull the engine down... and the trim is stuck up. If the trim weren't stuck up I could get by in the water.
