Re: Can I put a 75hp on a 50hp rated aluminum boat?
Have you had an aluminum boat before? There is no buoyancy in aluminum, like wood. If you throw a piece of aluminum into the water, it drops to the bottom, wood will float, and provide a degree of buoyancy for a certain amount of weight resting upon it. Aluminum just displaces water around it! That's the difference. Changes in weight distribution in an Alum. boat will produce fast & hard movement, if you're not prepared, you, or a passenger can get hurt or be thrown overboard. Amplify that by putting a too heavy, to powerful motor on it,,, that's why max weight, & horsepower is listed. The power, & prop torque on a 75hp motor is probably enough to roll you over if you happen to speed it up in a slow turn, because there is not enough beam on a 16' boat. Plus, any quick slowing down, may cause water to come in over the transom, and there's no stopping it if that happens, you could get swamped! Remember, that's on flat water,,, imagine choppy, or rough water!
Do you still want to put that 75hp motor on this boat?
