Re: Can I get away without painting the bottom of my boat?
You have to find out what suits your boat.
I mean theres a lot of different antifouling paints to choose from,From hard to soft , self polishing etc.etc.
Here in the caribean Antifouling is nearly a yearly returning choir,some peeps use coppercoat its suposed to last 7 years or so...cost a fortune too.
talk to the storemanager he should be able to advice you on everything.I advice you to take it all off(sanding) since you do not know what kind of paint it is..some paints dont play well together.you might have to prime afterwards too.
, a thing to remember two compound does not adhere well to one compound paint.
what I mean is if you use a one compound primer,use a one compound paint.
A two compound primer can be painted over with a one compound paint.NOT the other way around.use acetone to clean .
After you did this a few times you will get better at it it might look like a heap of work but you will do fine.
One last thing...Always start painting at the back of your hull.
use protection. facemask,overall etc. get advice at store.
Good luck.
Regards I mike
