can I do a compression check without a carb on the motor?
storedaddy
this might be a silly question. I am looking at buying a parts motor 9.9 johnson that does not have a carb. and I want to know if the powerhead rings and pistons etc are in good shape still.
thanks.
trendsetter240
Re: can I do a compression check without a carb on the motor?
Yes, engine should still have compression with the carbs off. Compression exists as long as the reed valves are closed.
G DANE
And even with the reed valves off, compression will be next to the same, I had one with a broken leaf once, on one cylinder, still had same compression never the less.
reeldutch
reeds build up crankcase compression and vacuum always overlooked on a 2 stroke.
its a way to transport intake to the cylinder.
on a compresion test it doesnt matter its just air.
