Darren Nemeth
- Dec 25, 2007
- 561
For my Batboat overhaul I need to replace the air scoops, those things that look like "eyes" on the bow. [illustrated in the attached image]
In order to do this one of the things I need to do is peanut butter fillet new air scoop panels along the sides, topside.
Will I be able to securely bond these new forms using poly resin and wood flower mixture directly to the gel coat or will I have to grind the areas down to the fiberglass??
Thank you in advance.
