- Jul 23, 2011
- 52,437
Re: Can anyone help me with information on this stern drive and hints for motor swap
you can use the motor if its pre-90. other than that, you could use the whole thing if you want to redo your stringers and transom to close up the hole. the cobra uses a small key-hole shaped hole just like mercruiser. the OMC stringer you have has a hole big enough to pass the arse-end of the motor thru (hence the big boot).
so i have found a good deal on a hull with a cobra outdrive and 3.0 how hard would it be to do a complete drivetrain swap or is there a way for me to use just the motor on this boat not sure of the year i know yall said it needed to be pre 90 i guess if its after that would be my question is there a way to use it
