can a stator fail only when warm?
rxrgoose
is it possible for a coil in the stator to separate when warm and cause failure. if so it wouldn't show up on a bench test
GA_Boater
When I used to repair military electronics in the pre-digital age, one of our tools was a high wattage hair dryer to heat components while testing.
The same can be done if you suspect a heat related stator failure.
