Can a 1976 15HP carb fit on a 1990 9.9HP Evinrude ?
909
Can a carb from this:
Fit in this :
Can the older 76 carb fit in the newer 90 outboard ?
kbait
As stated, that motor is 92 or newer. The 15 carb would fit on a 1990 9.9, but not on 92 and newer.
909
Can confirm it's an E10RECC which makes it a 1998
Would any 93 and up 15 carb fit ... or ... is it recommended only getting a 1998 and up 15 carb
oldboat1
has no carb, I gather. I would get a used '98 and rebuild it.
Why not put a 20 hp ( 1996 model 20 hp) carburetor on it.-----Use the adapter plate.-----Then it will really make the boat fly.
909
It has a regular 9.9 carb. What's an adapter plate ? Can you really make a 20 fit ????
