Can 20" drive shafts with different spline counts be interchanged?
ottersea
I have a 1993 70hp elets. One of its cavitation fins is badly damaged. I have an intact 1988 lower unit which uses the same housing as the 1993 but its drive shaft has four splines. The '93 drive shaft has 17 splines. Can I switch the shaft from my '93 to the '88 housing or are their other issues I am not aware of which would make this impractical?
Honorary Supreme Mariner
Read this carefully !-----------You can swap the housings over.-------If you want to just swap the shaft you will need to do some shimming.
Faztbullet
If you keep the 93 gears with the 93 shaft no shimming will be needed.
