Campion Victoria/Explorer Info...
Swedefj40
Since there is very limited information on the 1991-2006 Campion Victoria/Explorer model of boat (the one with the hard top/cabin) available anywhere, I'd like to post what I have on the subject. Feel free to correct or update any info here. I DON'T CLAIM IT TO BE 100% ACURATE!!! Use at your own discretion.
Campions were built in Kelowna BC, Canada until August of 2022.
Model runs:
1991-1996 (Victoria 215)
1997-2000 (Victoria 627)
2001-2006 (Explorer 622)
2002 - 2005(?) Construction switched to composite/Kevlar materials
Inboard/Outboard and also bracket options
My 1996 215 Victoria specs:
Hull Length: 246" or 20'6" (24.3' OA anchor to prop)
Hull Width: 94" or 7'10"
Weight with I/O: 3200 lbs (1452 kg)
18* deadrise
Fuel cap.: 189L (50 USG or 41.6 UKG)
Fresh Water cap,: 40L (10.6 USG or 8.8 UKG)
Engine:
4.3LX (180hp) 1000hrs
Weber 4bbl (600 cfm) carb, divorced choke
Prop (oem) 14.5" x 19" 3 blade aluminium
A1G2 (1.81:1 ratio)
Closed Cooling
Kicker:
Merc 15hp, 4-stroke
Here is a promotion ad for this model. Not sure which year specifically though.
