Re: Calling epresutti
Safari,
Most of the radius you see are butt joint. I would glass the unseen edge and then set my saw at 30 degrees and cut the seen edge. After that I used a belt sander to radius the joint. Sometimes I just eyeballed it and used the belt sander, then finished with a palm sander.
Before I would sand the seen edge of any joint I would let the unseen glass set completly so that it would hold the structure while I butchered, er um.. I mean sanded the finish edge.
Also the gunnels are two layers of 3/8th plywood, with a layer of glass in between. In some cases I left a "tab" of dry glass between the layers to join it to other parts.
Everything has at least 1 layer of glass on both sides, I used mostly 3/4 oz.
I hope this helps you with your project.
Peace.
Ed.
