novicetech
Thread starter- Joined
- Jan 19, 2004
- 267
I have a problem with an old Chrysler model 7071 70 hp that I took apart and cleaned up and reassembled over the winter. I am having trouble getting the motor to idle in gear. I can get the motor to start good until I put it into gear, then it will not idle unless I have the throttle open about a quarter of a turn. The new parts in the motor are, gaskets, impeller, t- stat, needles and seats and by pass valve. Also crank seals and diaprahm for fuel pump. The fuel hose was new last year. I also have tried two different new primer bulbs that go soft while running at idle. The fuel connector fittings are also new. The gas tanks were both new last year one is a tempo the other a sea sense. It will idle if you keep the primer bulb pumped up, and runs great at WOT. By the way my compression readings are 120 120 118. Any ideas will be appreciated.
