Calling All Outboard Gods !!!!
Big'n
Hello all, im a total newbie to the site, but i need help.... so i am calling to the outboard GODS !!! lol....
I have 1955-1960 5 hp Gale Buccaneer (RUNS LIKE NEW !!) It has a bad water pump and im trying to change it. Problem i cant get the lower unit off, i can not figure out how to release the shift linkage, someone told me that the shifter is the pin that releases it, but i can not figure out how to get the shifter out, or find any kind of release, no nut, no bolt, no clip, no pins, no allen screw no NOTHING .... Hook me up guys im tryin to go fishing lol..
steelespike
Re: Calling All Outboard Gods !!!!
You have to remove the power head to unhook the shifter.Sounds scary but as I understand it no big deal.
No service manual?You may find one at the library.
F_R
I am not God, but I do talk to him.
Seriously, you have to pull the powerhead. While you are ordering parts, get a new 303355 gasket and 303347 o-ring for the carbon seal. You will know what I am talking about when you get in there. Don't ignore this advice!! That is a vital assembly and will destroy the motor if it leaks. Some numbers for you:
391391 complete water pump kit.
379764 just the water pump impeller if you are cheap.
303467 powerhead gasket if your motor is mounted on springs
306205 powerhead gasket if your motor is mounted on rubber
303355 gasket for carbon seal plate
303347 o-ring for carbon seal
Parts available from your Johnson or Evinrude dealer.
If you go for the complete pump kit you will find it is different than the old one. Don't worry, it's better.
Big'n
AWESOME !!! Thanks guys Much Thanks !!! power head removal hmmmm.... sounds Fun ill give her a shot, lol... thanks for the parts list also you reckon that is all i am goin to need ?
next question, this little motor runs like new NEW EVEN lol... would it make more since to sell this engine to someone that is not goin to actually use it, you know like a collector and try to find me something that is not 50 years old, or do you guys think i should fix the water pump and use the GALE man she does run nice..... not sure what i want to do .... i do know i need something to go fishing with lol. thanks again guys
baconbiscut
Fix it, run it .you won't be sorry. super sweet engines and easy to work on and they last forever.
Big'n
i will let you guys know how the power head removal goes just as soon as i figure out how to do it lol.... an i think your right ill keep the little beasty ... why not it was free lol
F_R
You didn't give the model number or exact year, but the basics are remove the 7 screws holding the powerhead on, and disconnect / remove any hoses, carburetor controls, or linkages that prevent it from lifting off.
Big'n
THANKS GUYS !!! got the lower unit off, changed out the water pump, and all the gaskets and what not that were suggested, got her all back together and guess what ...... I didnt screw up anything she is working BEAUTIFUL thanks for the help guys ... only problem now is I didnt think that she was goin to be that easy to fix so i bought a 72 6 hp evinrude Fisherman with gas tank, life jackets, anchor, 3 extra props and running stand, for 75 bucks and she run BEAUTIFUL also, and has a little more nutts also so now what do i do keep the Gale, or sell the Gale ?
Big'n
anyone know how old this thing is, here is the model no. 5D15B serial no. 690893 what would be a fair price to ask for this engine, it is in perfect working condition, no parts needed, runs great, but the paint is a little chipped up she is old lol
F_R
It is a 1958. Does it still have all the plastic medallions, unbroken?
Big'n
it is a 1958 your right i found it online also, 1958 Buccaneer Gale 5 hp with forward , neutral, reverse, high and low adjustments on the front, all the knobs. and all ALLLL of the emblems are like brand new, i dont even think they are scratched, well maybe scrathed but not much if at all. if it had new paint on it it would look new again pretty easy i think. I was told NOT to paint it though.
tmcalavy
Keep it as a backup, pass it on to a younger relative when they get old enough to get interested in boats/motors.
eagle light
I'm new here - hope I'm posting this message in the right place! I have my dad's 1961 (?) Gale 5 hp Model #5D19B, Serial #828246. It needs a water pump. Earlier in the thread the part numbers for an earlier model were given - would the water pump be the same for mine? Thanks!
CATransplant
I don't know that outboard, but, please read the thread at the top of the page that tells you how to get your questions answered. Tacking onto an old thread doesn't work, and this thread had a poor title, anyhow.
Try asking your question in a new thread, identifying the problem and the year and model of your outboard. Then, someone who knows that outboard will read the thread. Otherwise, your question may go unanswered.
F_R
eagle, yes your motor should be similar. Yours is mounted on rubber, so takes a 306205 powerhead gasket.
See you on a new thread if you need anything else.
eagle light
I am new to forums, and don't know how to start a new thread. If you can help me with that, I could ask my question there.
Otherwise, F R, is your earlier message with part numbers for a water pump for a 1958 5 hp Gale valid for my 1961 5 hp Gale? You said "similar", but that scares me!
Thanks!
