Re: Calibrating a tachometer
495-<br /><br /> IF you have a Merc tach, you may be able to calibrate it. The newer ones have an adjustment screw on the back side. You'll need to hook up an accurate shop tach (inductive pick up will work) to the engine. Compare readings at the middle of your rpm range and adjust as required. For example, most outboards run up close to 6000 rpm, the tachs are calibrated at 3000 rpm. As you know, I'm not a MerCruiser guy, so I imagine you'll want to calibrate that thing around 2500 rpm.<br /><br />-John
