Calco Trim Pump
crazy_cowboy_01
I am having the same problem with my calco pump. I'm looking for a replacement and found some on eBay like the one pictured above. Omc 980940. Will this work as a replacement ? It has the same bolt pattern. It's just that it's a 2 wire and the calco is a 3 wire. But isn't there a way around that?
Honorary Supreme Mariner
2 wire and 3 wire use different solenoids and relays.---Not a direct easy swap..
