Calco trim assembly questions
jackson2
Hello all,
I've been fighting with a Calco TnT assembly off of a 76 Johnson 115. I've rebuilt the cylinders (for the most part, one gasket didn't want to fit), and the sender unit was shot. Being I don't have a trim gauge, I've just plugged the hole.
Now....I was disassembling the motor/pump assembly, as I couldn't figure out how to hook the electrical connections back up...and I think I found a problem. I'm thinking that the first time I cracked the top (two years ago) that I was able to reconnect everything with no issues (but TnT still didn't work, so I went to rebuilding cylinders). If not mistaken, something moved freely on the motor side in order for me to connect the electrical.
Anyway, back to the problem. I removed the pump assembly, and I assume that the shaft up to the motor should turn freely, correct? If it doesn't turn freely, any ideas on breaking it loose? I would think that the armature assembly would slide ride out of the field, but maybe not. I also didn't see a way to separate the reservoir from the motor housing. (To either replace or rebuild the motor).
I know that I could get an aftermarket CMC unit for my TnT, but just trying to save a couple hundred....though I may be better off just getting the CMC.
Any help would be appreciated!
Thanks!
