Cajun fuse locations
kfire01
I hope this is the right place to post this question. I am trying to diagnose a bilge problem, and I can't find the fuse for the pump. 1994 Cajun Fishmaster 1850, Johnson 120. Anybody ever work on one of these?
bigwalk
Re: Cajun fuse locations
I have a 1980 cajun bass boat, i'm having problem's with the trim and tilt not working. Trying to locate the fuse panel, and relays i can jump it at the silenoid will go up and down. When I try to use the switch on the throttle lever nothing happen's.
Art Bernard
Banned
The normal place for fuses would be inside your stearing console, if not there look around where your battery is located. I believe most bildge pumps use a brown wire for power so when you find your fuse block look for that. If the switch for the pump is located on your console, it's a good bet the fuses are close by. Is there any removeable panels it might be hiding behind? Irriguardless, it's gonna be between the battery and your console.
Art
capkirk
I have a 1996 Crest II Pontoon and the horn works occassionally. I need to advice on where the fuse box on this boat is located and what amp to use when I do find it. Any other suggestion greatly appreciated.
