cable steering to hydraulic steering old p/s pump
newtoboat101
1988 mercruiser 5.0lx motor ,switching from cable steering to hydraulic steering ,i am also adding raymarine ev150 autopilot.with type 1 pump I have added hydraulic helm,and ran hoses to back of boat ,so i took old helm box, ram and cable out of boat, My question is what to do with old power steering pump and hose from oil cooler ,i am not going to use power assist on new hydraulic steering ,do i remove old power steering pump entirely ,and what about the power steering cooler that hoses run thru ,do i get new hose to run from thermostat housing to outdrive (this is hose that runs under motor) ,so can i eliminate old power steering pump and all hoses to this ,thank you in advance
Tie the input and output hoses together and simply pull the belt
newtoboat101
ok ,cool do i drain the fluid out so i will be dry ,but disabled ,and what about the hose from the p/s pump to ram ,pull off completely?
newtoboat101
and take pump fluid cooler total out, and replace with adapter to connect hoses?
no, dont drain it dry, leave it full of oil.
tie the two pumps to the ram together.
newtoboat101
sorry about ,misread your first message disregart my other messages,,i now see what your saying
