Cable and pulley steering and a new motor
Leahcim
I have a 1963 15' Starcraft with a cable and pulley steering system. I don't want to convert to a modern steering system. The issue is I need a new motor and I have a line on a new Suzuki DT30, 30 hp 2-stroke, I live in Baja California where new 2 strokes are available. I'm wondering if the motor will have the tab in the center front to attach the steering cables. Anybody know?
GA_Boater
Don't know for sure, but the specs say tiller/remote - Most likely.
Leahcim
Thanks for the reply. I think I'll be OK. If I have it pictured correctly both the old cable/pulley and the modern systems connect to the motor in the same spot.
GA_Boater
The cable attachment connects to part #34, where a steering link arm attaches with the newer steering systems. Your motor will be similar, the drawing may be for an older DT30, so not exactly as yours.
Leahcim
Thanks a lot! I appreciate you taking the time to respond. 8^)
