Re: CA glue as filler for hairline gelcoat
Crack repairs can be a hassle and time consuming because to make the repair last there is a good deal of work involved.
Simple fixes like coating it with epoxy or trying to super glue the cracks don't address the real issue that caused them in the first place, so they tend to be short term at best.
If these are cracks from repeated flexing, then you need to find the reason for the flex and stop it. Is it poor support, bad laminate, poor design, etc and then fix that issue.
Was it a one time impact...then you need to see if the laminate has been damaged and fix it if is, otherwise this will be a weak area and crack when it flexes.
If the cracks are just from the gel coat being too thick, then even if you just fix the crack the gel coat is still too thick and very susceptible to cracking...again.
You have two options.....if they aren't critical like he said, then you can just leave them alone. Or go the whole route and fix them right.
Failure to fix the underlying problem will result in the cracks coming back, possibly before you even launch the boat.
