Re: bypassing key or relay
Buy yourself a remote starter switch Sears sells them and your favorite autoparts don't cost much ,this will keep you from flinching everytime it sparks when you use a wire or screwdriver and sticking your finger between the flywheel and starter,1 lead to the battery cable from the battery on the solenoid the other goes to the small post that has a yellow wire with a red stripe,leave key OFF so it does not start,remote starter switch can be used during compression test and for other troubleshooting purposes
