buzzer
mcruea
does anybody know how to test the buzzer and how many wires go to it
thanks;)
WillyBWright
Re: buzzer
There is probably a sensor on the cylinder head. Jump the wire to it to ground with the key on. That should sound it. The horn gets 12v+ with the key on. If it gets grounded by the overheat sensor switch, it sounds.
mcruea
Re: buzzer
im just wonding theres a orange wire and a red wire goes to the horn , but i have a black(ground) wire hanging by it and theres a screw on the back of the horn so i was wondering if the wire goes there or some where eles if you put the wire on the loose scew it sounds
eurolarva
Re: buzzer
That wire is a spare ground to use for instrument guages like Tach and speedometer. You can use it as a test ground for the buzzer but dont leave it hooked up permanantly or the horn will sound non stop.
