Buying a new Alpha, Debating Changing the Gear Ratio
greg82255
Well, I just torched an Alpha drive by forgetting to put in gear lube. Rookie mistake. Now I am buying a new drive, but I remember a few guys talking about switching the ratio. It's a 383 stroker mated to a gen 1 alpha which was previously a 1.5 ratio. I've heard of a few guys going to higher ratios and pairing them with higher pitched props (I believe it was wca_tim that did this) and getting more speed out of their boats. Just curious if anyone had any insight into this subject. I'd like to order a new drive asap.
HT32BSX115
Re: Buying a new Alpha, Debating Changing the Gear Ratio
Well, I just torched an Alpha drive by forgetting to put in gear lube.........................Champ II - 1986 Formula 206 Spider, Vortec 383 Stroker/Alpha One (until it blows up, then maybe a Bravo)
Yeah. I would do a Bravo too (also) !
Tail_Gunner
That is intresting larger prop same revs and higher speed's... i believe someone left out drag. It would be nice for a elaboration on this...As to drives i just picked up a sei for a 454 after a bit of research... we will see how it goes. In your case you would have a 3 yr warranty. Along this journey i have met more than a few merc guy's that spit at this drive but it is the same drive and the parts interchange.
Ayuh,.... There Used to be 1.32:1 gear sets available, used with the BBC's, 'n for some reason some 351 Windsors,.....
I haven't seen a New set available for Years,....
Donno why you'd ever wanta got to a 1.65:1,... you'd need props in the mid- hi- 30"s, +
What kinda barge ya pushin' with the Stroker,..??
Tail_Gunner
I believe I just came to a answer of some sort. The gearing on the 1.8 gears are larger less gears lager width. That should make them more durable...maybe not but for now I will stick to the appropriate gearing
greg82255
I am pushing a Formula 206 Spider - I ended up just buying the 1.47 ratio from SEI. I didn't want to lose any more boating days this summer by debating what to do. The boat is going to be up for sale at the end of the year anyways.
Tail_Gunner
Follow the break'n procedures closely,
