buying a 23 ft weekender
dvx216
This spring I'm looking to buy a 1985 to 1989 23 ft weekender with this said is there any thing I should be looking out for with the model
nlain
Re: buying a 23 ft weekender
Have not been in here for a while so just saw this. There was a lot of wood used in boats of that era, so rot is a thing to look for, decks, transom, stringers. You also want to check for age and use damage, wear and tear, if it has been well cared for there may be no problem at all but the chance is there. Probably the best advice to give you is get a survey on the boat you are looking at, surveyors know what to look for and how to check for problems.
