KaGee
Thread starter- Joined
- Aug 14, 2004
- 7,069
USCG rules of the road...
The rule is subjective, in any case if the officer thought you were too close, you are screwed. Go wider the next time.
The overtaking situation. When one vessel is overtaking another vessel from any direction two or more points abaft the other vessels beam, that vessel is an overtaking vessel and is required to keep clear of
the other vessel. Any person operating a vessel shall not follow another vessel more closely than is reasonable and prudent and shall have regard for prevailing conditions so as to not create a risk of collision. The overtaking vessel should indicate the intended side on which it desires to pass and wait until the overtaken vessel responds with a similar signal
before passing. Violation of any of the above rules of the road is an infraction.
