bus heater install
orbit
Has anyone mounted a bus heater in a 245, and if so were did you mount the unit? I want to put one in but I am stumped as to where the best location for the unit to go would be .
Thanks!
gcboat
Re: bus heater install
Are talking about using the heat from your engines cooling water? Sort of a radiator type system?
If that's the case then I see it as nothing short of a PITA. Look at a small propane space heater instead.
briguy2817
Thanks!
I was a leadman for Ryder School Transportation in Illinois and would install those heaters all the time. The biggest problem is after about a year, they started to leak. The 12 volt motor that would help circulate the antifreeze would eventually go out as well. So, you would be stuck with nothing more than a heater core. It will still exchange heat, just not as well without the blower on it.
I'm not sure if it would work with a I/O set up since those pumps are designed to be installed on a closed system. If you didn't stray too far from the motor you could get away without the circulation pump.(10 feet or so)
As it was previously mentioned before, it may be easier to get a small propane heater but, now you have to deal with Co and fire hazard.
Brian
briguy2817
Thanks!
Brian
dan t.
I have a 1992 2452 it came with a dealer installed buss heater in the step leading into the cabin. it hooks up with ordanary heater hose to the engine at the water pump and at the intake manifold it has a 2 spd fan and has worked perfectly for the 6 years that I have owned the boat. my boat has a closed cooling system with a heat exchanger, with raw water cooling and dirty water I suppose it could plug up
